9 mm Thru Axle - Ve...
[Closed] 9 mm Thru Axle - Very Tight?
[#7757557]
Building up my new Roadrat. The 9 mm thru axle is really tight. I can't push it through the hub. I reckon it will go through ok if I tap it with a mallet. Is this normal though?
My maxle glides through.
Posted : 09/04/2016 11:32 am
Slides through easily on mine (Superstar hub and aluminium axle). Are your end caps inserted okay?
Posted : 09/04/2016 11:46 am
I had a problem with the axel on a set of xfusion forks. Not sure if this is relevant but see this:
[url= http://singletrackworld.com/forum/topic/why-cant-i-get-my-bolt-through-axle-in ]http://singletrackworld.com/forum/topic/why-cant-i-get-my-bolt-through-axle-in[/url]
Posted : 09/04/2016 1:37 pm
Mine seems to either the axle is too large or the holes in the hubs are a fraction too small. Will try grease and failing that some wet and dry. Maybe the anodising is too thick round the holes.
Posted : 09/04/2016 2:03 pm
