89mm threaded BB wh...
[Closed] 89mm threaded BB what are my options ??
[#11286182]
Hi
So I've bought a frame that's arrived 89mm bb should be for a pressfit but it's threaded ,gone through PayPal as item not as described and got a refund but I'm not sure what to do with the frame ???
If I can keep it what do I do with it ?
Any help or ideas would be great
Posted : 07/07/2020 9:30 pm
What diameter is it?
Posted : 07/07/2020 9:33 pm
I'd be curious to know what size of thread is in there as a BB92/PF41 BB shell is bigger diameter than a regular BSA threaded one.
Posted : 07/07/2020 9:40 pm
I’m not sure what to do with the frame ???
Send it back?
Posted : 07/07/2020 9:46 pm
It was purchased from Taiwan so posting it back would be expensive and if Corsair want it back they can pay the postage ,the thread is normal as I've screwed in a Shimano hollowtech bb
Posted : 07/07/2020 10:12 pm
I don't think 89 threaded is supposed to exist, 68,73,83,100mm is all I know of.
Posted : 07/07/2020 10:17 pm
And here lies my problem , not even sure why they made it like that major f up by someone
Posted : 07/07/2020 10:20 pm
What's the I'd similar to? Do you know someone with a lathe that could turn a sleeve for you? Run some.smaller press fit bearingsbut with same BB axel I'd?
Posted : 07/07/2020 10:27 pm
I don't know anyone like that ,I was wondering if a 83mm bb with spacers would fit but not sure I'd have enough spindle on the crank to attach the non driveside crank arm
Posted : 07/07/2020 10:35 pm
Would facing off 3mm either side be an option, checking chainring and crankarm chainstay clearance issues first.
Posted : 07/07/2020 10:46 pm
That could be possible if I could get an engineering firm round Nottingham to do that
Posted : 07/07/2020 11:04 pm
What material and are the threads deep enough if you get it cut down?
Probably easiest option is if you can hacksaw off a sliver each side and get a bike shop to do a final face up / tidy up the thread. They won't want to trash a facing tool removing loads of material (especially if Ti or steel). 3mm a side with a facing tool in aluminium wouldn't be unreasonable (but I know nothing about 83mm threaded bbs and cranks to suit).
Posted : 07/07/2020 11:18 pm
It's a steel frame zona Columbus I think
Posted : 07/07/2020 11:41 pm
Bb won't be Zona - probably some kind of cromo at best so not too tough but shops with facing tools probably not keen on chunking off that much but would happily skim it square.
I'd help out but not nearby unfortunately. Any local framebuilders?
As you said, a machine shop could do it. If you can screw some old bb cups in below the surface, get it milled off and then unscrew the cups it will tidy up the threads on the way out.
Posted : 07/07/2020 11:51 pm
Could I get a Dremel and smooth out the threads so a bb92 would fit ?
Posted : 08/07/2020 12:17 am
A saint 83mm bottom bracket uses spacers like a 68mm bb, couldn't you use with just one 2mm DS spacer, then its only 0.5mm too long on NDS.
Posted : 08/07/2020 8:00 pm
Thanks Greeny30 that might just work
Posted : 10/07/2020 7:48 pm
