Hi all, as title really , does anyone know if there are any available as I can't seem to track any down.
Thanks stuE , should have said in my post that max budget is around £40 though.
Just add some extra spacers to a lower rise stem!
Or higher rise bars.....
Thanks guys , can't add spacers as the steerer isn't long enough , considered using higher rise bars but would like to shorten the reach a bit hence the shorter stem with more rise solution .
Rental Strata duo. You need look no further. Just bin a 10mm spacer to slam it a bit.
That rental duo, is 50 odd quid on that German website.
Rough calculation (I may be wrong, haven't done maths in some time), but you'll only lose less than 1mm in length due to the rise of about 8mm. I could well be wrong though.
A 50mm 10degree stem will only buy you <2mm in height gain over an 8deg stem, only 3mm on a 6degree. Not worth the extra bucks I reckon... Consider finding a stem with a smaller stack in a more readily available rise and adding a spacer below of the difference.
