456, E-13 and HTII ...
[Closed] 456, E-13 and HTII BB
I took this lot apart to swap the BB over, and on putting it back together the front mech (which I didn't move) doesn't line up with the rings properly anymore. I suspect I've cocked the spacers up despite being careful to count them off from both sides.
Anyone know exactly how it should go? I think I've got, from NDS
Cup -> Frame > Spacer -> E-13 -> Cup
Posted : 10/06/2010 8:43 am
If it's a 73mm shell, then ditch the DS spacer as the backplate replaces it.
Posted : 10/06/2010 8:57 am
Hmm - according to On-One, it's a 68mm shell which means you should have a spacer on either side plus the backplate.... this won't change your chainline, only your NDS crank positioning.
Either the web info is wrong and it's a 73mm shell, or it was set-up wrong previously....
Posted : 10/06/2010 9:04 am
456 is 68mm for sure. sillyoldman has it right.
Posted : 10/06/2010 9:14 am
Actually, there may be a spacer on the NDS also.
Do you get different sized spacers?
Posted : 10/06/2010 9:33 am
2 spacers on the drive side, 1 on the non drive side,
or
1 spacer on each side + chain device
or
if its ISCG (Summer season frames?) then you need 2 spacers as the chain guide is on the frame not the BB.
Posted : 10/06/2010 9:51 am
No, it's a standard DN6 456
I'll have a play about with it. Are BB shells different sizes? It wasn't a Shimano one that came off
Posted : 10/06/2010 10:08 am
