4 bolt rotor
[Closed] 4 bolt rotor
[#3053948]
can you still get 4 bolt rotors?
I've an old Cannondale / Coda rear wheel that I'm thinking of using for SS use but it takes a 4 bolt, not 6 bolt rotor.
any ideas?
Posted : 16/08/2011 12:52 pm
Hope can do custom ones, not sure if they can help?
Posted : 16/08/2011 12:54 pm
that's good to know but I bet they cost a bomb.
I suppose I could get an adapter made as an alternative
Posted : 16/08/2011 12:58 pm
Hope still make them, around £30.
Posted : 16/08/2011 7:05 pm
Bought one a few monthe ago, sure it as much as £30 more like £23 or so.
You need to order via your local Hope lbs, i used Evans
Posted : 16/08/2011 7:52 pm
I've got an old unbranded 160mm one you can have.PM me.
Posted : 16/08/2011 8:11 pm
[url= http://www.ebay.co.uk/itm/Rohloff-Speedhub-4-bolt-160mm-Disk-Rotor-Made-HOPE-/200632654831?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb6a35bef ]http://www.ebay.co.uk/itm/Rohloff-Speedhub-4-bolt-160mm-Disk-Rotor-Made-HOPE-/200632654831?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb6a35bef[/url]
Posted : 16/08/2011 8:24 pm
Prob to get the bolt spacing right;
[url= http://www.ebay.co.uk/itm/BANKRUPT-BIKE-CYCLE-DISC-ROTOR-4-HOLE-165mm-NEW-/380357669539?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item588f1572a3 ]http://www.ebay.co.uk/itm/BANKRUPT-BIKE-CYCLE-DISC-ROTOR-4-HOLE-165mm-NEW-/380357669539?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item588f1572a3[/url]
or
[url= http://www.ebay.co.uk/itm/BANKRUPT-BIKE-CYCLE-PAIR-DISC-ROTORS-4-HOLE-165mm-NEW-/170358709348?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item27aa2b9c64 ]http://www.ebay.co.uk/itm/BANKRUPT-BIKE-CYCLE-PAIR-DISC-ROTORS-4-HOLE-165mm-NEW-/170358709348?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item27aa2b9c64[/url]
Posted : 16/08/2011 8:29 pm
thanks guys, clearly I didn't look hard enough.
nick, I'll mail you when I'm not on my silly small phone screen
Posted : 16/08/2011 8:55 pm
OK, I've emailed the shop but anyone know what bolt spacing the Rolhoff is? I dunno if it'll be the same as my wheel. I've looked on the web and cant find it.
Thanks
Posted : 18/08/2011 7:03 pm
Only got a tape measure handy, not a vernier.
It looks like 65mm between centres of diametrically opposite bolts. (65mm PCD)
8mm bolt holes.
2" hole in the centre.
Posted : 18/08/2011 7:20 pm
Bugger, Mine is about 45 PCD.
Thanks
Posted : 18/08/2011 8:28 pm
Rohloff disc PCD is the same as a granny ring.
Posted : 18/08/2011 8:33 pm
