3speed shifter fall...
3speed shifter fallen apart
 olib
[#13535427]
Evening:
advice please- my SLX left hands shifter fell apart and I’m sure some parts are lost.
its a band on sl M660 SLX no window - possibly 2012. 3x10 set up.
can buy these new on its own?
my son wants to do a pairs adventure race in 12 days and I will Need the granny ring at some point!
Thanks
Posted : 05/05/2026 11:44 pm
Topic Tags
 Alex
I'm sure I have a couple of those in the spares bin. If you don't get a good answer drop me a msg and I'll post it to you. I'd need to check tho, defo have one for two chainrings, not sure for three.
Posted : 06/05/2026 8:33 am
Yours brand new for the princely sum of £15, complete with window and multi-release, by the look of it
Posted : 06/05/2026 9:33 am
 olib
Ah thanks!
ideally don’t want a window thingy in it- do you if they can be removed.
appreciate the link 👍🙏
Posted : 06/05/2026 9:46 am
Probably not removable tbh, not without leaving the innards open to muck and bullets anyway.
Posted : 06/05/2026 9:53 am
I'm pretty sure Shimano used to secure the cover you needed if you removed the shifter window to the underside of the shifter window itself. I have definitely had little disc shaped covers that go over the hole where the shifter window used to be.
The exploded diagram on the SJS link shows a cover for the removed shifter window.
And another website selling the same shifter:
Shimano SLX SL-M7000 SLX shift lever; band-on; 2/3-speed left hand – BikeParts.co.uk
has this in the description:
  • Removable optical gear display with integrated cover allows the use of these shifters with any brake lever
A review of the 11-speed (RH version) comments specifically on this (scroll down to the review):
Shimano SLX SL-M7000 SLX shift lever; band-on; 11-speed right hand – BikeParts.co.uk
Posted : 06/05/2026 10:30 am
thelawman and olib reacted
