30mm to 24mm BB ada...
[Closed] 30mm to 24mm BB adaptors
[#12101642]
I've been doing some looking for adaptors to be able to use shimano cranks on a bike with PF30.
The adaptor cant have a wide flange as the BB shell is already 92mm. Can't see any like that but has anyone know of any that might fit.
Looking at this as a cheaper option (got a spare shimano crankset) to replacing the 30mm turbine cranks on my bike as the crank arm / chainring interface is buggered on the crank
Thanks
Posted : 05/11/2021 9:47 pm
Wheels Manufacturing- available through Madison/Freewheel or your local shop have lots of solutions including a threaded replacement for PF30 which I have used successfully- initially expensive but then you can just replace the bearings. I think Kinetic Bike Bearings did some adaptors as a cheaper, temporary replacement too.
Posted : 05/11/2021 9:53 pm
Problem solvers top hats
I use these, and was expecting them to wear out fairly quickly.
However, they've been spinning happily away in my fatbike for three years now.
Posted : 05/11/2021 10:08 pm
I’ve used the raceface top hat adaptors with no issues.
Posted : 05/11/2021 10:15 pm
How did you screw the interface?
Posted : 06/11/2021 1:20 am
