30mm Bottom Bracket...
[Closed] 30mm Bottom Brackets. Hope?
 rhid
[#10165760]
I need to replace my Raceface BB. Its normally an easy choice of a Shimano one but because I now have RF turbine cranks I need a 30mm one.
Are the Hope ones better value? Can the bearings be replaced when they wear out etc? I am fed up of the shimano way of sealed units and stuff being disposed of and want to generate as little waste as possible!
Posted : 13/08/2018 12:27 pm
Bearings can be replaced, mine are 2.5 years old and one side starting to fell a little rough.
Posted : 13/08/2018 12:34 pm
you make it sound like you go through 15 a week! 😆
Posted : 13/08/2018 12:37 pm
I fitted my new Hope 30mm yesterday to replace the original RF one.
They need a special tool as the outside diameter is bigger than Hollow tech II and the RF one. I got my special tool from Charlie the Bikemonger which arrived super quick.
Take care when pre loading the bearings. I managed to muller my pre load ring by over tightening the lock screw. It is made of very soft plastic.
Hope bearings can be replaced.
Posted : 13/08/2018 12:50 pm
I've replaced bearings in both Rotor and hope BBs. Some swearing was involved - I think I need to find something better to hold the cup as I knock out the bearings (maybe an old dead steel/alloy frame that I can clamp in a vice) but it is doable. I've found the stock hope ones to outlast rotor, but the rotor ones are cheaper.
Posted : 13/08/2018 12:51 pm
The Hope ones are slightly narrower than the RF ones so you may want to add a few 1mm spacers to adjust your chain-line.
Posted : 13/08/2018 1:25 pm
