Just purchased a couple of 104bcd rings to change from 3x10 to 2x10, but not sure if I also need to change derailleur to accomodate?
Anything else I should be wary of when changing over?
Posted : 15/02/2013 6:11 pm
You could use a medium cage mech if you want, but it's not a necessity.
Unless you use a bash guard you will need shorter chainring bolts for the medium (now big) ring.
Posted : 15/02/2013 6:15 pm
Cheers...I think the rings are coming with the correct bolts.
Posted : 15/02/2013 6:19 pm
Do you need to change the front mech from 3x10 to 2x10?
Posted : 16/02/2013 4:21 pm
