is this at all possible? what exactly would you need? my mates after going from 3x9 to 2x10.....as cheaply as possible?
he doesnt use granny ring, nor doesnt use the large ring (but does occasionally for road use)...so ditching the granny ring is an option....
would it mean next chainset? cassette? etc? or just new front fronts? and also do you go about doing so?
thanks!
or alternatevly just 2x9?? guessing then no need for the ten speed cassette etc?
any ideas folk?
Why wouldn't it work?
And why bother if you want it on the cheap? Save your money for something else if it's in short supply.
I run my Five 1x9.
2x10 is mostly duplication. A 1x10 with a 34T front ring would be pretty spot on. Having said that I've had absolutely no issues with 1x9.
Issues with pivot/swingarm clearance with chainrings bigger than 36 unless you space them to the outer position...and corresponding wacky chainline.
You'll notice orange don't spec 2x10 (only double and bash).
