2x style dropper re...
[Closed] 2x style dropper remote
Quick question, can't fit a shift lever style remote as I've got a twin lock lever where that would go. Is the RaceFace style 2x lever worth the extra over the Brand-X one?
Are there any others?
Posted : 17/03/2020 12:43 pm
This is a Specialized Command post lever - it should work with most cable operated posts (I think) - I've used it with a Tompson dropper.
I have two that I dont use anymore - one fits in place of a Specialized grip lock ring (as in the photo) and the other is a normal bar clamp.
Dont know if that would solve your problem but if your interested i'm sure we could sort something out.....
Image result for specialized command post lever
Posted : 17/03/2020 2:45 pm
Is your twinlock remote over or under the bar?
Mine are under: I use a Giant branded one: it can be used right way up or upside down.
https://www.cyclestore.co.uk/giant_switch_seatpost_x2_lever_and_cable_set-ID_74271?sv_source=google&sv_medium=cpc&sv_campaign= [campaign_name]&sv_term=[keyword]&gclid=Cj0KCQjw6sHzBRCbARIsAF8FMpWO-b_6OEPYxWfi6Li0PULAnv2hzkTC6fRcubEz4zqCHlalyfKk8G4aAjfrEALw_wcB
I am sure there are others that are similar.
Posted : 17/03/2020 2:52 pm
