29er recommendation...
[Closed] 29er recommendations
[#5550419]
Been looking at getting a 29er hardtail through cyclescheme for work duties and also trail days when the susser doesn't need to come out.
Been looking at the Genesis High Latitude and possibly the Singular Buzzard (would be cheapish custom build). Any good things to say about these two, any others worth looking into?
Posted : 26/09/2013 10:10 am
Buzzard is a great ride, great pedalling, great climbing, great pointing down etc. Most fun 29er ht I've ever had and all without having to compromise any other aspects usually associated with a fun bike to ride.
Posted : 26/09/2013 10:46 am
Can I throw the Whyte x29 series too into the mix? Great bikes.
Will come in lighter than those you've chosen being ali as both of your mention are not light frames (still no doubt great bikes), and basically similar geo (ok longer CS's).
Got a lot of good press..
Posted : 26/09/2013 10:55 am
z1ppy you've mentioned 2 things I wouldn't buy in a 29er longer chainstays and aluminium
Posted : 26/09/2013 11:02 am
Why?
I'm not saying there hugely long, just longer than those above (dependant on the way there measured...), there still shorter than many others.
As for no ali, why not for the OP, he's asking for recommendations? (you may have you own personal choice's but does he?)
It'll make the bike significantly lighter for the same components, and any "flex" of a steel frame is dependant on it's build/tubing, so you've no guarantee.
Supposed I should also mention the Trek Stanche too, as another ali alternative option 😀
Posted : 26/09/2013 11:16 am
My preference would be for a steel hardtail but that does limit my options and I do have a price limit with it being through cyclescheme.
I have looked at the Trek Stache as a friend has one and I do quite like it.
Posted : 26/09/2013 11:32 am
You can top up cycle schemes can't you?
(I suppose that may be scheme dependant).
OK hows about the Piperdream Scion R853 or Sirius R853, Cotic Solaris, Kenesis Decade Virsa or Ragley Bigwig
Posted : 26/09/2013 11:43 am
I probably could top it up through the shop I will buy from as I know them but don't want to go OTT with the build or price just yet. Solaris is probably a bit pricey but I do quite like em
Posted : 26/09/2013 12:08 pm
Being a Solaris owner I'd wholeheartedly recommend it, yeah it will cost a bit more...
Are you able to spread the cost of that increase?
It also depends on if you're planning on keeping it longer than C2W scheme.
Posted : 26/09/2013 12:34 pm
Solaris, but spec an Exotic Carbon rigid fork & SS & it should come in under £1k. You'll be surprised how rideable such a machine is.
If you need gears, pick up the 1x10 bits from Bike.de etc later.
Posted : 26/09/2013 1:14 pm
On-One Inbred 29er?
Posted : 26/09/2013 1:21 pm
I have spare bits I could use if i went the custom build option, providing I can get frame, forks and wheels from shop via cyclescheme.
Posted : 26/09/2013 2:36 pm
