Morning all,
What is the best option for a suspension for for a light rider?
My wife's fork has never worked that well, and would like to replace it with something that does...
29er flavour - tapered.
Cheers all.
Paul
How much travel?
100mm.
Reba if you're strapped.
SID if you're feeling flush.
Float 32 works well for me at ~60kg
55psi
Another vote for reba
Got a four ride old Rockshox Reba for sale if you are interested
[url] http://singletrackworld.com/forum/topic/fs-29er-rockshox-reba-rl-120mm-forks-150 [/url]
fifeandy - Member
55psi
I'm fairly light, although not as light as this^,but also am getting on really well with Fox Float 32.
I have a lightly used 100mm 29in Reba, tapered with 15mm axle that I was probably gonna sell.
Drop me a line if that would fit the bill.
Cheers all...
Tracey- are those U-Turns? If not is the travel adjustable?
And Chakaping- line dropped.
Not u turn but Im told they can be adjusted to 100mm.
Thanks Tracey= I will check with Joanne tonight to see what she thinks.
Paul
If they're recent Rebas, you change the travel by swapping airshaft for about £30, much same as Pike etc.
Older Rebas were the old style 'adding spacer to shaft' style for travel adjust but I think that's really quite old in terms of SH forks now... 2012 sticks in mind for some reason?
My current Rebas came with a MoCo damper and 120mm shaft fitted, but the original damper and 100mm shaft in the box, so I know this works.
I have a Float 32 29er 100mm travel CTD fork with 3-position remote lock-out for sale - £150 posted. Can send pictures if you're interested?
