29 plus sus forks?
[Closed] 29 plus sus forks?
[#9830020]
What forks have people successfully ran 29plus tyre in?
I fancy the duro crux 3.25” but doubt there are many to fit that tyre
Please add to the short list I have, any experience and knowledge welcome
RS Pike 29+
Rs Yari 29+
Manitou magnum 29+
Posted : 11/02/2018 12:59 pm
Pretty sure a bluto will take them, though there are other issues there...
Posted : 11/02/2018 1:57 pm
magnum is a great fork if it's a Pro which has the Dorado air system and the hydraulic bottom out. I've got one on my Stache. Manitou also make a Machete 29+ but it's a bit anorexic for most.
I managed to run a 29x3.25 Vee Bulldozer in a Magnum Pro but you wouldn't want a mudguard of any description as well! owing to not having much clearance,
Posted : 11/02/2018 2:06 pm
I have a Bontrager Chupacabra 3.0 in a normal Fox 32 29er fork on an i35 rim
Will probably end up with a Dirt Wizard, as they’re a tiny bit smaller, but have ridden in filth with no ill effects so far
Posted : 11/02/2018 2:18 pm
Thanks for the replies.
I nearly snagged a set of magnums cheap but the steerer was to short!
I wondered about these
https://www.bike-components.de/en/Fox-Racing-Shox/34-Float-29-130-Grip-Rhythm-51-Boost-Suspension-Fork-2017-OEM-p61616/
I know some fox forks have big clearance
Posted : 11/02/2018 2:54 pm
I would be staggered if they don’t fit, presuming you fit one of the smaller 29+ tyres eg a Terrence McFly or Surly Dirt Wizard.
At that price I’m a little tempted to get some myself to beef up the front end on my set up, but they boost fsctor probably makes it prohibitive
Posted : 11/02/2018 3:35 pm
 st
I ran a 3” Minion DHF in a Yari+ and with a mudhugger type guard the clearance was close. Not an issue other than mud scraping regular on cruddy rides but no catching.
If there were such a thing as a Minion 3.2 I think it would have been a problem.
Posted : 11/02/2018 4:11 pm
A bit niche, but Maverick SC32 forks work well with 29+ and fat wheels.
It is a proprietary hub, but you can get an axle kit for Hope and some other hubs.
Posted : 11/02/2018 4:26 pm
I have a Minion DHR 3.0 that fits in my MRP stage with reasonable clearance, but not loads of room for mud once you a Marshguard type mudguard as well. I've got a set of those Fox forks too so could possibly see what clearance is like, but not a for a couple of days.
Posted : 11/02/2018 4:47 pm
Thanks again all for the replies.
Generally I like my Rs forks but I could be persuaded elsewhere .
I’m keen on adaptable bikes and parts,
So a fork which can serve 27+ 29 and 29+ With the ability to change travel height if need be would be great.
I think the Yari 29+ has this covered ,now to wait for a set to come up cheap s/h!
Posted : 11/02/2018 6:04 pm
Sorry to say old chap that a crux 29+ won't fit into any fork I know off. It to tall for a bluto (bigger outside diameter than a 5" fatty rubber) won't even give clearance on RS judy29+ and they are specifically designed to take biiiig tyres on wide rims. On the plus side they will happily run 29+ dirt wiz and bombolinis on a 45 and 52 rim and swallow 650b+ 3" without any issue what so ever. The crux is just a sodding massive tyre but works a treat rigid. To be honest if it was going on a big rig for flatout rocky stuff, I'd stay away from it as the sidewalls are not the beefiest. A minion dhf 3" would be a better bet for yobbo antics in the 29+ world and there's loads of forks that will run that
Posted : 11/02/2018 6:59 pm
Thx Tazzy that’s very helpful.
Just trying to cover all bases.
But I’m taking it to the extremes which are probably not necessary .
Posted : 11/02/2018 7:25 pm
