28 hole, 29er rear ...
[Closed] 28 hole, 29er rear wheel?
I have some good quality lightweight 28 hole hubs going spare. I want to build them into a light but tough 29er wheel set.
Will they be stiff enough? Especially on the back? It's to go on a 120mm travel Nike, that's used for general trail riding. I'm around 72kg so nor too heavy.
I'm not sure whether a rim like an arch mk3 will be stiff enough? Or maybe a light bicycles carbon job?
Posted : 08/11/2016 8:32 am
4 more spokes on the back isn't much weight, im not sure I'd skimp forbthe sake of a few gramms personally.
Posted : 08/11/2016 10:06 am
I had a specialized enduro 29er hire bike for a few days and it had a 28 spoke rear wheel, can't say I noticed any flex. I was riding some tough trails with rocks and jumps etc and weighed about 100KG including kit/water etc.
For general trail riding I think you'll be fine as long as you use a good rim and spokes, i'd go for a DT Swiss EX 471 personally.
If I was building wheels from scratch, i'd go for 32 hole but if I had really nice 28 spoke hubs, i'd just use them.
Posted : 08/11/2016 10:19 am
New Trek X-calibers (and presumably Superfly's etc) come with 28 hole rims/hubs, so look at Bontrager suff.
Posted : 08/11/2016 2:09 pm
The 2016 Nukeproof 290's were on 28 spoke SRAM Roam/Rails. Make of that what you will.
Posted : 08/11/2016 3:51 pm
Yep, got a shock when I realised the wheel set on my new Superfly was 28 spoke. Holding up fine so far and I'm not exactly flyweight...
Posted : 08/11/2016 4:01 pm
 jimw
My DT Swiss XM1501 29er wheels have 28 spokes, they seem perfectly stiff enough and I weigh 90kg.
I also have a 29er rear wheel with only 20 spokes that has lasted nearly four years and is still as straight and true as the day I bought the bike. Thats is certainly stiff enough
Posted : 08/11/2016 4:10 pm
DT do the XM481 in 29" 28 hole, good mix of weight, width and toughness.
If you were a bit heavier or riding a bit more 'gnar' I'd nudge you towards the tougher EX rims but you should be fine with XMs.
Posted : 08/11/2016 4:33 pm
Spank Oozys here with 28 holes back and front. Holding up superbly well. Six months in and perfectly true. I think I notice some flex sometimes (it's hard to tell!). What I have done though is not gone lower than 30psi after wrecking my Hope Enduro rear running lower pressure.
Posted : 08/11/2016 4:35 pm
thanks for the feed back.
I think ill give them a try
Posted : 08/11/2016 7:11 pm
28 holes dt Swiss hubs here with dt revs and.... Carbon rims too!!!... No spontaneous combustion as yet ๐Ÿ˜‰
Posted : 08/11/2016 9:10 pm
