27.5 wheel in a 29e...
[Closed] 27.5 wheel in a 29er fork ?
[#8276746]
Got an On-one Parkwood in 29er flavour, it's in a Large. However it feels a bit 'big' compared to my Whyte T130.
Last week i checked a few things out geometry wise and it's not actually THAT much bigger than the Whyte in TT length, reach etc. But i was thinking of combining my thoughts a little bit and moving both bikes to 27.5
So what i could do, is buy a Parkwood 27.5 frame in a Medium. I'd then swap all my bits over from the 29er to the 27.5, O-O are knocking frames out for £89 so not a massive outlay, but i'd also get that back as i've got 2 sets of 29er wheels i could sell on to recoup the frame cost. I've got spare wheels for the 27.5 so that's not a massive issue (although i would need a rear wheel as mine is a 142x12 which is to fit the Whyte and i need a QR for the Parkwood. But no biggy, i could sort that i guess.
The only downside with this plan is one i slightly forgot at first... I've got 29er forks on the current Parkwood. Which would mean unless i ran a perculiar 29er front/27.5 rear (i don't fancy that), then i'm running 27.5 front wheel in a 29er forks...
The other plan is i guess to order the Parkwood 29er frame in the Medium instead... but the Large isn't THAT large for me in honesty and seems a little excessive to swap just for a frame size, especially as the frame is pretty much worthless as it stands due to their pricing.
Posted : 08/01/2017 4:27 pm
Don't bother. I know the frames are only £89 but it's one of these things where the costs just snowball. Get a shorter stem for the parkwood to match the reach to what you like and you'll be right.
Posted : 08/01/2017 4:38 pm
Stick the 27.5 wheels in your existing parkwood and save your money to fund a new back wheel/axle. I run 29er forks on my Bird Zero (It's what I had available) and they work perfectly with 27.5 wheels.
Posted : 08/01/2017 5:08 pm
Here's mine, 29er Trace forks on a 27.5 frame. Lot's of tyre clearance. 🙂 A-C is 540mm and Bird recommend 542mm so all good.
[img][url= https://c3.staticflickr.com/1/512/32038903642_273f811995_z.jp g" target="_blank">https://c3.staticflickr.com/1/512/32038903642_273f811995_z.jp g"/> [/img][/url][url= https://flic.kr/p/QPaKQo ]IMG_1843[/url] by [url= https://www.flickr.com/photos/136285034@N02/ ]Paul Harrison[/url], on Flickr[/img]
Posted : 08/01/2017 7:13 pm
