27 Inch/700c wheel ...
[Closed] 27 Inch/700c wheel help needed please!
[#776422]
Just bought myself an old raleigh road bike to build up as a fixie/singlespeed (havent decided yet) It came with 27 inch wheels on it, can 700c wheels be used? i would guess it would cause problems with brakes? Im sure one of you lot will know the answer.
Cheers!
Posted : 11/08/2009 2:27 pm
Yep, there should be enough adjustment in the brakes to be able to do it. You realise you can get a reasonable selection of 27" tyres though, if that's the factor?
Posted : 11/08/2009 2:29 pm
Ah cool, thanks. That was kind of a factor but the wheels are pretty ****ed so just wanted to know if i had more options for finding bargains!
Posted : 11/08/2009 2:36 pm
700c will work, you might need deep drop brakes depending on the frame though.
Posted : 12/08/2009 8:48 am
i have some unused road 27" tyres you can have for postage if you change you mind
Posted : 12/08/2009 8:55 am
I'll keep that in mind Junkyard! thanks very much 😀
Posted : 12/08/2009 7:19 pm
