26 wheel in a 27.5/...
[Closed] 26 wheel in a 27.5/650b fork
Thinking about future proofing any upgrades to the trusty Alpine 160. And was thinking that if I upgraded the fork in the near future(such as to a Pike) would I be able to get my 26 front wheel/tyre combo in a 27.5/650b fork? I assume you can and it'll just have a bit more clearance. I know it will slightly change the geo of the bike but no more than swapping out to a 170mm fork or a slightly taller A2C.
To. Kp
Posted : 09/07/2014 9:03 pm
It'll be fine. Extra offset should pretty much cancel out the change in feel from the extra A-C length. You might need to drop your stem down the steerer a bit.
To. Kp ?
Posted : 09/07/2014 9:16 pm
Works fine, and if you have "big" tyres, you can hardly tell the difference:
Static:
Not so Static:
๐Ÿ˜‰
Posted : 09/07/2014 9:53 pm
I run 160mm 650b fork on a 26 inch bike meant for a 170.
Really bad photos as my phone is low on battery so no flash.
Tyre is a 2.4 Chunky monkey which is slightly smaller than the less grippy Hans Dampf
Posted : 09/07/2014 10:12 pm
There was a recent article in The Lancet where researchers definitively showed that doing this results in a mild case of death.
Posted : 09/07/2014 10:20 pm
Yep - its like crossing the streams in Ghostbusters.
Posted : 10/07/2014 12:36 am
Rocking the William Morris there fr0sty ..
Posted : 10/07/2014 5:14 am
Your wallpaper hedge^^^^ could do with a trim...... ๐Ÿ˜‰
Posted : 10/07/2014 10:08 am
