25mm to 15mm throug...
[Closed] 25mm to 15mm through-axle hub convertor?
I have a front wheel that came off my Enduro, it has a Specialized hub which uses a 25mm through axle (to suit the E150 fork). For the moment, I want to use this wheel with a DT Swiss XMC 130 fork (on a different build), this has a 15mm through axle...
Anyone found an adapter that'll do this? googling doesn't find me anything, sorry ๐Ÿ™
cheers ๐Ÿ™‚
Posted : 10/12/2009 7:12 pm
You can get adapters for 15mm (and 20mm and 25mm) for the Roval Traversee wheelset from Specialized, but I bet it's not the same as the hub you've got. You're best bet is probably a rebuild (or new wheel) with a Hope Pro2.
Posted : 10/12/2009 7:21 pm
The 15mm one must be new? I have a set of traversee's and they came with 20mm and QR adaptors only (bought earlier this year)... I'll give Spesh a call in the morrow and see if they can help out. cheers ๐Ÿ™‚
Posted : 10/12/2009 7:28 pm
you can get them thru your local Spesh dealer (unfortunately Spesh won't sell them direct to you), part numbers are S2030036 and S2030037.
Posted : 10/12/2009 7:46 pm
thanks guv'ner ๐Ÿ™‚
Posted : 10/12/2009 7:47 pm
thats the best thing about standards, they are so many to choose from....
Posted : 10/12/2009 7:49 pm
indeed... it's a pain ain't it!
Posted : 10/12/2009 7:50 pm
 J273
Thought id post here instead of starting a new thread.
Are there any 3rd party adapters available yet or are they atill ony available through spesh themselves?
Thanks
Posted : 21/09/2010 2:47 pm
