20mm front axle gre...
[Closed] 20mm front axle grease
[#6315224]
Hi I'm going to be using a 20mm front axle and I have heard a lot about them getting stuck and you should grease them every now and then.
I was thinking of using park tools polylube 1000.
Any thoughts on this grease or a better one for the job?
And what about the 12mm rear axle does that need the same?
Posted : 03/07/2014 7:38 pm
Depends how often they come out. More often they come out, the less need there is to grease.
Any grease will do.
As a fitting instructor at work once said, grease it, grease it all. But if you can see the grease, you've used too much.
Posted : 03/07/2014 7:50 pm
I doubt I will be taking it out much
Would putting some of it on a rag and just wiping the axle be enough?
Posted : 03/07/2014 7:52 pm
Just a dab and smear it all over with your fingers. Remember, these axles are a very close fit so there isn't really any space between faces for the grease to sit.
Posted : 03/07/2014 8:12 pm
Alright, thanks for the advice 🙂
Posted : 03/07/2014 8:14 pm
