2012 zesty what bb ...
[Closed] 2012 zesty what bb and crank?
[#6735058]
Hello I have just bought a zesty frame and wondering what bb and chainset I can fit? I want to keep cost down as much as possible. I intend to run 1 x 10 (never done this before either) but assume I can run any crank just using a narrow/wide ring in the middle.
Am I looking for a bb90 bottom bracket and what is a good cheapish one to get? Can i run a standard shimano crank i.e. something like and SLX?
cheers for any help.
Posted : 29/12/2014 5:34 pm
You won't like my answer but the only decent long lasting quality press fit BB is the hope one not cheap though... £100 ish but I went through xt/fsa ones in weeks... Hope has been fit and forget for 12 months and counting
Posted : 29/12/2014 5:54 pm
Nukeproof do a metal pressfit one. It's on CRC's website, working well for me.
Posted : 29/12/2014 6:01 pm
Hi mate, originally it was a shimano bb90 bb running xt cranks so presume slx will be ok. When I first went 1 x 10 i used the middle ring which was a 32 and a mech with a clutch which worked well.
Posted : 29/12/2014 6:32 pm
IIRC the KCNC press fit has replaceable cartridge bearings too. Worth a look.
Posted : 29/12/2014 6:49 pm
cheers, so BB90 is what I am looking for and it should fit a standard crankset? Thanks Bitterlemon I might send you an email if that is cool, I didnt want to bother you.
As i tend to buy oldish kit I havent kept up with BB sizes. Are there large crank axles for the new larger BB's? Or do they take a standard crank axle and just have the bearings internally?
Cheers....
Posted : 31/12/2014 2:06 pm
