2011 Bottlerocket
[Closed] 2011 Bottlerocket
Hi all,
Has anyone seen a 2011 Transition Bottlerocket up close?
I'm liking it over the Mega at the moment, specifically for the travel adjust. Does anyoen know how that works, or have any other general impressions? Shock options?
Anyone know where I can go and see one?
Posted : 31/05/2011 1:51 pm
bump
(Ooh, I've never "bumped" before. It feels dirty.)
Posted : 01/06/2011 12:36 pm
 GW
why would you want travel adjust??
Posted : 01/06/2011 12:59 pm
 jedi
my mate has just got one. it rides the same as mine. he prefers it in the short setting too.
shit bit is tapered headtube but it came with 11/8 domians.
Posted : 01/06/2011 1:30 pm
 GW
I'd rather have a lower leverage ratio over more travel any day too.
adjustable travel (at the linkage) is something you'll hardly ever use on a tough play/DH bike, and if you do it's way more of a faff than just switching the shock pin setting.
Posted : 01/06/2011 1:38 pm
Travel adjust would add a bit of tweakability.
Short setting for slightly more progressive action, mid/end-stroke support. This is for ragging around, trail-bike style days, would let you pop out of corners a bit more.
Long setting makes it slightly more linear and "coil-y", can run more sag, for days where you are soaking up slightly bigger hits.
Don't know if it would affect the BB height/head angle (which is why I was asking how it worked).
Marry up adjustable rear travel and my 140-160 forks up front and I would be getting a pretty flexible bike.
EDIT: I would probably keep it in the short setting most of the time, but having the option would be nice.
Posted : 01/06/2011 1:42 pm
Looking at this I'd say it was just a swap of position for the shock on the link.
Posted : 01/06/2011 2:32 pm
That's sort of what I thought, but the holes are different sizes.
Posted : 01/06/2011 3:02 pm
The bolt prolly screws into the link directly, so to switch travel the bolt needs screwing in from the other side as the big hold for the allen bolt end would make that part of the link too thin. Probably.
Posted : 01/06/2011 3:05 pm
Moving the linkage will more than likely seriously change the leverage ratio, so you will need to put a heavier spring when increasing the travel.
Not to bad if its using an air shock, total pain in the arse if you using a coil over.
Posted : 01/06/2011 3:09 pm
Yes, was thinking air. RP23 or similar.
Posted : 01/06/2011 3:16 pm
If the leverage ratio is over 2.66 then you are going to need to put a lot of air if you are heavy, which in turn won't make the bike ride very nicely.
Posted : 01/06/2011 3:18 pm
 5lab
richc - Member
well, yes and no. yes it will adjust the leverage ratio, but if you still want to run (say) 20% sag, won't the old shock still sag by the same amount (but be 20% of the longer travel)?
that might not be right, but my head can't figure it out
Posted : 01/06/2011 3:40 pm
 GW
I'd go and have a wee lie down ๐Ÿ˜‰
Posted : 01/06/2011 3:51 pm
what GW said.
20% sag when the leverage ratio increased from 2.66 to 3 (typical values) will be more like 30% sag.
Which is fine for a dedicated downhill bike, however in reality you will be running 30% sag on your trail bike, so you are in the 40-45% sag territory and that's before you hit a bump, so you are going to be smacking your pedals everywhere.
Posted : 01/06/2011 3:55 pm
 GW
looks like the shock pin threads straight into the linkage plate, in one position it threads in from drive side while the other threads in from non drive side. The design keeps it neat, negates the need for a nut and probably saves a little weight over other mounting options.
Posted : 01/06/2011 4:00 pm
Definitely needs a test ride, I think.
I don't exactly get how leverage ratios affect things. Anyone care to summarize?
EDIT:
Hang on. Some quick back-of-fag-packet calculations suggests that the ratio is 2.3:1 in short travel and 2.6 in long. That sound better?
Posted : 01/06/2011 4:06 pm
That sounds much better. If you are heavy anything with a leverage ratio over 2.66 I wouldn't bother with, so that sounds fine.
Posted : 01/06/2011 4:14 pm
And with the same weight coil at those rates it'll be sprightly in short travel and more saggy in long travel, which sounds like what you were after in your earlier post.
Posted : 01/06/2011 4:29 pm
 jedi
i got mine set up with a dhx air. rides lovely at herts. getting used to it not being the demo9 too ๐Ÿ™‚
Posted : 01/06/2011 9:15 pm
