2010 lappiere zesty...
[Closed] 2010 lappiere zesty headset
Any ideas what headset I would need for this frame? I've bought the frame with no headset and want to make sure I'm ordering the right one. Cheers
Posted : 05/04/2015 12:40 pm
Hope Integral is the headset I have in my Zesty of that vintage.
Posted : 05/04/2015 1:09 pm
2010 Zesty's took an 1"1/8 semi integrated (or at least my carbon 714 does)
Posted : 05/04/2015 4:30 pm
Is semi integrated the same as integrated?
Posted : 05/04/2015 7:44 pm
No. Integrated headsets have the bearings sitting directly Into the machined head tube, semi integrated bearings sit in the frame but in separate bearing races.
Posted : 05/04/2015 8:57 pm
I'd recommend getting the headtube measured with a vernier caliper, Lapierre have been known to use some odd size cups on some of their frames.
Posted : 05/04/2015 9:02 pm
I run a works components angled semi- integrated headset in my 2010 zesty 914 - works a treat !
Posted : 05/04/2015 9:11 pm
Pretty sure its a 44mm headeset. Thats what my spicy needed anyway.
Also means you can run tapered forks with a 44EC lower cup.
Posted : 05/04/2015 11:06 pm
