200mm rotor, will a...
[Closed] 200mm rotor, will a 203mm adaptor work?
[#8095371]
Quick question, I have a sram centreline 200mm rotor, and looking for an adaptor to fit it but most of them are made to work with 203mm rotors? Will a 203mm adaptor work?
I'm running a pike fork with Shimano brakes if it makes any difference?
Posted : 07/10/2016 11:45 am
it will be put by 1.5 mm
Essentially yes but a reduction in braking power so small you wont notice
Could easily file that off the adapter anyway
Posted : 07/10/2016 11:49 am
Bigger (potential) issue would be the 1.5mm lip of unused brake pad rather than the drop in power
Posted : 07/10/2016 11:50 am
If you cant find a 200mm mount give me a shout on ben@birdmtb.co.uk. We have a squazillion of them.
Posted : 07/10/2016 12:00 pm
Cheers Ben I will do, it's for an Aeris too!
Posted : 07/10/2016 12:07 pm
it works great until the pads wear so that the two unworn sides touch, but the pads dont touch the rotor...... (i have also done this)
Posted : 07/10/2016 12:33 pm
Well in that case you can have a free one. In the post for you already 🙂
Posted : 07/10/2016 12:48 pm
^^^^Now that's customer service
Posted : 07/10/2016 1:00 pm
benpinnick - Member
8) 8) 8) 8)
Posted : 07/10/2016 1:04 pm
That was impressive. 8)
Nice one Ben.
Posted : 07/10/2016 1:06 pm
Cheers Ben, your a star!
Posted : 07/10/2016 1:34 pm
I have an adapter from Bird for a 180mm disc which needs an aeris to mount it on if anyone can help?
Posted : 07/10/2016 2:12 pm
This is why I bought an Aeris 🙂
Posted : 07/10/2016 6:19 pm
