Will that work on HT a with a non clutch rear mech and without a chain retainer?
Or am I looking for trouble and numerous trail stop to put the chain back on?
I ran it for a while a few years back, but I added a chain device soon enough as it was a bit annoying although the chain drop wasnt as bad as I thought it might have been.
cheers.
My 456 has an Ace components 42t along with 32t NW and a normal slx mech. Only dropped the chain a couple of times. When the mech dies I'll replace it with a clutch, but its fine as it is for now.
I run 1x10 with Hope 40Trex, clutch mech and NW chainring. No chain retainer. Occasionally during cleaning I'll knock the clutch off and forget to put it back. Not had chain drop yet. This is on a HT.
I ran 1x10 with a 40T OneUp sprocket, Zee mech and RaceFace 30T chainring for three months in Greece last year - so lots of rocky, rough terrain, probably similar to what you have.
I had no chain problems, apart from when I picked up a piece of baler twine.
This was on a Genesis Alpitude.
Your choice of front chain ring will make a big difference. Also the length of your rear mech cage
Are some front rings better than others?
