1x10 help
[Closed] 1x10 help
[#5897467]
So i'm running 3x10 with a clutch rear and would like to go 1x10.
Do I need a thick n thin chain ring?
And do I need shorter bolts or any spacers lining up the rings?
Posted : 27/01/2014 10:08 pm
A thick/thin or narrow/wide chain ring is a good start. You'll more than likely need shorter bolts depending on your cranks. Merlin were kind enough to give me some FOC (although they were mech hanger bolts) when I bought my Raceface ring of them. You may need to move / add spacers on the bottom bracket if you have them to get a suitable chainline.
Posted : 27/01/2014 10:12 pm
You can pick up single ring bolts from eBay cheap enough, I recently got some black ones for about £6 posted.
I still run one spacer on my drive side BB and have had no issues with my chainline, although removing it wouldn't do any harm.
Narrow wide ring & clutch mech is the future in my opinion, although I've heard of people running normal rings with no problem, but I'd recommend a NW for more security.
Posted : 27/01/2014 10:16 pm
How do I go about sorting a chainline?
Posted : 27/01/2014 10:17 pm
Limited options really, remove a BB spacer on the drive side if you have too many?
Run a single specific crank, although if you run the single ring where you middle is you shouldn't have too many issues tbh.
Posted : 27/01/2014 10:25 pm
I wouldn't worry. Just stick your chosen 32 tooth ring in the middle ring slot and job done. It's far simpler than you might be thinking. Might need a top guide if you go for a plain chainring, but it's not rocket surgery.
I ran a 1 x 10 with the normal ring whilst waiting for my n/w ring to arrive. Had it with a clutch mech and didn't drop the chain once. Depending in what rings you have now it might give you an idea of what size n/w to go for. I had a 28/40 chainset so ended up going with a 30t n/w.
Also be interested in how you go about setting chain line..
Posted : 27/01/2014 10:26 pm
For the cost of a N/W ring - just get one and save the faff.
You will need smaller bolts.
Plenty of choice for rings now, RF, Blackspire, E13, Works Components
I went for a Works one, its cheapest and made in the uk and I am a bit of a batty about stuff like that 😉
Posted : 27/01/2014 10:28 pm
I moved from 1x9 to 1x10 and have done nothing to improve my chain line, no need.
I do however run a single specific crank but I believe the only difference is there's no granny ring tabs.
As Rickos said, simple conversion so I wouldn't put too much emphasis on the chainline, NW & and clutch is all you need for simple, client running gears!!
Posted : 27/01/2014 10:30 pm
Would 36T be a bit big for Peak district area?
Unless you have legs like Chris Hoy I'd say yes!
32 or 34 is best for Peaks.
I run a 32 and ride there all the time absolutely fine.
What cassette are you planning on running? If you're going to run a 11/36 you could get away with a 36 upfront but I think the most common set up is 11/36 with a 32 or 34 up front.
Posted : 27/01/2014 10:31 pm
I'll buy a 34T and buy shorter bolts tomorrow.
Posted : 27/01/2014 10:37 pm
Good shout 🙂
Posted : 27/01/2014 10:38 pm
Better follow the fashion
Posted : 27/01/2014 10:44 pm
Oh it is a 36/11 on the back
Posted : 27/01/2014 10:52 pm
Yep, easier on the legs uphill!!
CRC are doing SLX for £27 or XT for £37, bargain!!
Posted : 27/01/2014 10:55 pm
Just use your middle ring and get some shorter chainring bolts and a chain device. I ran my canyon nerve like that for about a year with no issues whatsoever.
Although for the price of the e13 xcx device I had, you could probably get a thick/thin ring?
Posted : 27/01/2014 11:03 pm
