185mm/2.75" shocks ...
[Closed] 185mm/2.75" shocks - where or who from
[#285811]
i ordered a DT swiss shock at 190mm expecting it would fit and it clearly isn't going too. who makes 185mm rear shocks?
Posted : 08/02/2009 1:44 pm
 GW
185mm eye to eye? would have thought custom is your only option (or speak to the frame manufacturer).
surely you can't mean 185mm eye to eye & 2.75" stroke though, most 2.75" stroke shocks are 222mm eye to eye.
Posted : 08/02/2009 3:03 pm
no. i mean 185mm eye 2 eye, which is 2.75"
Posted : 08/02/2009 3:04 pm
 GW
in who's universe is 185mm = 2.75" ?
it's closer to 7 & 9/32"
Seems the idiosyncrasies of a tape measure are baffling you so before wasting any more time/money I'd suggest you contact the frame manufacturer.
Posted : 08/02/2009 4:02 pm
clearly i meant 7.25", numbers typed in the wrong order innit 😳
Posted : 08/02/2009 4:06 pm
if you made sense then it might be easier to help...
Posted : 08/02/2009 4:10 pm
 GW
all the information you need has already been given, do with it what you like 😉
I'd add you to my valentines' list too but couldn't be sure to find an accurate address for you what with all those numbers to remember 😛
Xx
Posted : 08/02/2009 4:12 pm
see above
Posted : 08/02/2009 4:13 pm
 GW
mrmichaelwright - Member
MTFU son! If you are going to act like a bit of a **** towards someone offering an honest reply to your question, at least have the balls to leave your original ****** reply the way it was originally written rather than run off and edit them.
Posted : 08/02/2009 11:04 pm
i DO apologise GW, honestly.
anyone got a slightly less condescending reply?
Posted : 09/02/2009 9:17 am
