Hi,
think I might have messed up on buying a fork on ebay (paid and dispatched and no returns). I have a hope front hub of 20mm, but the maxle on the new for is 15mm. Arse!
Is there any conversion kit I can use so they will work together or have I messed up big time?
Rob
If you have a hope pro 2 or evo then the end caps are easily available in most bike shops.
I do indeed.... could you point me in the right direction on crc or somewhere like that?
Be good to be able to swap it back so I can use my old forks for blasting through the winter mud ๐
can I buy a 15mm one of these? I gather I just pull out the 20mm end caps in there now?
that right?
The 20mm endcaps have a circlip holding them in .Just use a small screwdriver to lift them out.15mm caps just push in
sweet as... so that makes it easy to put the old pikes back in for winter ๐
sorry, can i confirm that the 15mm is the one i want on wiggle. Sorry, I know it's obvious, but I got a bit giddy today and bought forks that were not the right size ๐ Though I now gather the hub is the same by hope it's just the various caps you use.
Your link doesn't work for me,but yes 15mm end caps.
http://www.wiggle.co.uk/hope-pro2evo-front-hub-conversion-kit/?lang=en&curr=GBP&dest=1&kpid=5360648271&sku=5360648271&ci_src=18615224&ci_sku=5360648271uk&utm_source=google&utm_term&utm_campaign=All+Products&utm_medium=base&utm_content=sLmKJRNfV_dc%7cpcrid%7c%7cpkw%7c%7cpmt%7c%7cprd%7c5360648271uk
Your link doesn't work for me,but yes 15mm bolt thru end caps.
