1.5 straight steere...
[Closed] 1.5 straight steerer in a tapered headtube....?
I have just purchased some cut price fox 36 uppers from Mojo with a 1.5in steerer. I original thought I would be limited to a frame with a 1.5in headtube (intense tracer etc) but would I be right in thinking that I can also fit these in a tapered headtube if I use the top half of this Nukeproof headset....
http://www.chainreactioncycles.com/de/de/nukeproof-warhead-44eeos-headset/rp-prod85870
....and a standard zero stack lower race - significantly widening my choice of frames?
If so is it only Nukeproof that do these headsets?
Posted : 31/03/2014 10:16 am
Measure the top of the head tube, I'm using a 1 1/8th cup in mine and it's a fair bit narrower than the bottom hole.
Posted : 31/03/2014 10:19 am
tapered headtubes are normally 44mm at the top
Posted : 31/03/2014 10:22 am
I could go and measure mine bit it's got a standard 1 1/8th up top
Posted : 31/03/2014 10:27 am
OK - I didn't realize you can external tapered headtubes. The one I have seen are zero stack tapered headtubes (44mm top).
To be honest I'm pretty sure it will fit but just wanted someone to agree as I haven't seen it done before- pretty please!!!!!!!!!!!
...and if Nukeproof is the only option?
Posted : 31/03/2014 10:31 am
Look at the Hope link, they spec just about anything.
Other useful stuff
http://www.parktool.com/blog/repair-help/headset-standards
http://www.canecreek.com/tech-center/headsets/shis/overview
Posted : 31/03/2014 10:35 am
hope don't do them and as far as I can tell neither do Cane Creek
Posted : 31/03/2014 10:40 am
Nor CK.
If you can find a frame with a tapered HT and an upper 44mm cup, it's going to look a bit odd with an inset lower and an external upper...
Posted : 31/03/2014 11:18 am
Really
I think it would look quite nice
Im thinking of maybe a Trek Remedy
The only Issue I can see is the depth - the Nukeproof Top cup has a depth of 14.8mm. Its not clear what the depth of the bore is on these zero stack frames - but the Integrated 44mm hope headset is only 10mm in depth.
Posted : 31/03/2014 11:25 am
