New frame takes a 142 and my Hope Pro 2 has a 135mm Maxle. I can find axle converters but is there an adapter for the stepup in size maxle?
Posted : 04/11/2016 2:56 pm
If it's standard pro 2 not evo, you'll need a new axle and new end caps... And the new axle is allegedly a bit pants so you're better of getting the whole pro 2 to evo conversion kit... Having said that both my standard pro 2 142 axles are doing just fine
Posted : 04/11/2016 3:37 pm
No, you'll need a longer one AFAIK.
Posted : 04/11/2016 4:38 pm
Yip just had standard pro 2- and I guess it the x12 through version I need
Posted : 04/11/2016 9:57 pm
Is this what's required
http://www.chainreactioncycles.com/mobile/hope-pro-2-4-evo-rear-hub-conversion-kit/rp-prod68578
Posted : 04/11/2016 9:58 pm
Posted : 04/11/2016 10:53 pm
Contact Hope on Monday. They will sort you out with no hassle.
Posted : 05/11/2016 2:24 pm
