12lbs in my rucksac...
[Closed] 12lbs in my rucksack. how much in my shock?
 ton
[#4341675]
going offroad touring tomorrow for the week.
my rucksack weighs 12lbs (spare battery and charger for the leccy bike).
how much more pressure in the rear shock, same has the bag weighs?
Posted : 07/09/2012 9:53 pm
I had a bit more than that a few weeks ago and I put 20-25psi in there. I left the fork as it was to keep the front end down due to the wheelie-tastic climbs behind Loch Maree!
Edit: Due to the stupid amount of weight I had on my back. It was more of a bivi/fishing trip so the ride wasn't much of an issue.
Posted : 07/09/2012 9:54 pm
It's all about the sag.
Posted : 07/09/2012 9:56 pm
Please take this the wrong way but I'm trying to be helpful
Assuming you owned this bike through your successful diet isn't it a matter of going back to the shock pressure when you were 12lb lighter...
Posted : 08/09/2012 10:00 am
Surely it depends on what bike and frame you have as they all have different setups
Posted : 08/09/2012 10:10 am
[quote=ampthill ]Please take this the wrong way but I'm trying to be helpful
Assuming you owned this bike through your successful diet isn't it a matter of going back to the shock pressure when you were 12lb [s]lighter[/s] heavier ...
FTFY
a bit till it looks right (serious answer)
Posted : 08/09/2012 10:11 am
ton, you're still a big lad I think
what percentage of your overall weight is an extra 12lb - maybe 5% or so if you're 17 stone or so
as mws said, "a bit" - or about 5% more than currently
Posted : 08/09/2012 10:26 am
Depends on shock and bike and what you've currently got the pressure at, need a bit more info
Posted : 08/09/2012 10:33 am
[quote=druidh ]It's all about the sag.
oops thanks..
Posted : 08/09/2012 11:23 am
Put enough in to get ~20% sag.
Posted : 08/09/2012 12:05 pm
druidh - Member
end of really.
Posted : 08/09/2012 2:28 pm
What about 700psi? It's as likely to be correct as any other answer you'll get from here without knowing the bike, setup, rider weight etc.
On a more serious note you'll want between 15 and 30% sag depending on what type of riding you will actually be doing.
Posted : 08/09/2012 2:39 pm
I wouldn't bother changing it for just 12lbs.
I mean, that's just a good lunch, surely?
Posted : 08/09/2012 4:07 pm
