11.4018.021.000 Roc...
[Closed] 11.4018.021.000 Rockshox air spring
Newbie fork fiddler here so go easy 😂
I'm getting confused on the Sram site but I need this spring to change the travel on my 2013/4 29er Rebas to 120mm.
Any ideas if this part number is used in other fork models?
Thanks.
Posted : 25/06/2020 12:04 pm
Looks like it's the same for SID-B forks and both 27.5 and 29er Rebas.
Posted : 25/06/2020 12:47 pm
and from memory the SID were the same as the 32mm revelations.... same service manual
I've got a spare airshaft for the 32mm revs that grannyring can have which is 140mm on the 27.5's and if its not exact then I suspect either this or the spare 150 27.5 revs with the top swapped off his existing one would be the same.
Posted : 25/06/2020 12:53 pm
Bit of an update.
Ordered this airspring and it turns out that it's the same length as the one fitted in the forks so why am I getting just over 100mm travel, the forks are 120mm...?
They have been well looked after by the look if it.
Reba RL-A3 S/N 42T31433825
Any ideas ta?
Posted : 07/07/2020 10:04 pm
