10speed xt crankset...
[Closed] 10speed xt crankset work with slx 12 speed?
 goby
Hi all, ok so doing a new build and hoping to transfer some of my old parts over, will a XT m785 crankset work with the new Shimano 12 speed set up? Will I need a new chainring? Cheers
Posted : 21/05/2020 12:20 pm
Should be fine - I've got XT 10 speed with Sram Eagle GX and a Superstar Narrow Wide chainring
Posted : 21/05/2020 12:39 pm
 goby
Excellent thanks
Posted : 21/05/2020 12:51 pm
Shimano chain different though, and you'll only get the benefit of improved shifting with the Shimano chain, which requires a compatible 12 Spd Shimano compatible ring.
Posted : 21/05/2020 1:01 pm
It it's a single chainring up front I can't see how that'll change the shifting. Agree the Shimano 12 speed chain would be best.
Posted : 21/05/2020 3:57 pm
Sorry - to be clearer - you need the Shimano chain too get the advantage of better up and down shifts on the cassette. That Shimano chain supposedly needs a different chainring tooth profile.
Posted : 21/05/2020 5:33 pm
As above, Shimano chain can be fussy with some chainrings - in some cases, a SRAM quicklink sorts the issue, but other chainrings don't play well.
Posted : 21/05/2020 5:52 pm
