105 Shifter unwante...
[Closed] 105 Shifter unwanted movement
Hi, need help!!
My 105 11 spd shifter has started to play up.
I noticed it rattling when out on the road and have since discovered that the brake lever moves 6-10mm before it hits tension and starts to pull the brake cable. The only tension is the return spring. Once it hits tension, it operates perfectly.
What needs tightening?
He
G
Posted : 13/08/2016 8:41 am
the cable ?
undo the cable at brake caliper and hold it with your fingers and see if you still have some play .
Posted : 13/08/2016 8:44 am
Silly me, it's the caliper not fully returning...
Posted : 13/08/2016 8:48 am
