10 speed chainrings
[Closed] 10 speed chainrings
Hello,
Trying to go 1x10 going, does anyone know if a 9speed chainring work or will I need to get a special 10 speed ring?
Chris
Posted : 27/08/2010 6:47 am
noone? Or am I being thick?
Posted : 27/08/2010 3:10 pm
Poss not as the 10sp chains are narrow? Depends on chainring tooth width I guess?
Posted : 27/08/2010 3:27 pm
pretty sure you don't chris
Posted : 27/08/2010 3:30 pm
9 speed chain rings will work fine with a 10 speed chain, I've had that set up for a couple of years now.
Posted : 27/08/2010 3:36 pm
To get the best shifting possible then with a 10 speed cassette you should run a 10 speed ring. The 10 speed chain is directional and designed to work best with the proper rings and sprockets.
Posted : 27/08/2010 3:38 pm
inner dimension of 10 speed chain is same as 9 speed but 10 speed outer dimension is narrower so on 1x10 your current ring will be fine
Posted : 27/08/2010 3:54 pm
Thanks guys
Posted : 27/08/2010 6:20 pm
If you're fitting a 1x setup your best bet would be to fit a specific non ramped/pinned single ring like renthal/gamut etc.. The teeth on these are a bit longer so will hold onto the chain better on bumpy downhills, it may be a tad stiffer too.
Posted : 27/08/2010 7:11 pm
Showing your allegiances there, SRAM don't use directional chains ๐Ÿ™‚
There's enough people using 10 speed chains on 9 speed set ups to show that it'll work fine, not as well as with a 10 speed ring, but well enough.
Posted : 27/08/2010 7:14 pm
Oy, alpine boy, I ran mine 1x10 with a Race Face 9speed ring and a shimano roadie chain at Moray. It ruled.
Also, don't be a gay, join me and Huw with an e13 xcx. In white. They're bitchin'.
Posted : 27/08/2010 7:20 pm
Luke, here's my thinking,
Scale - 34, 11:34 9 speed xcx for training
Surge - 32, 11:36 10 speed e13 ls1.
tu approve?
Posted : 27/08/2010 8:14 pm
I ran 32, 11:36 at Moray and didn't even get up onto the 3rd biggest cog, so I reckon for Relentless 32:36 will be fine for day to day riding on the Surge. As for the scale, I'd say 32 up front with the 34T cassette but I spin like a girl.
I'd not bother with the beefiness of the LS1- Huw uses an XCX on the 5 now and it held up down Ben Lomond (we went a new way down, it's cool) without dropping the chain, and I've got a similar thing on mine that's just as good. No need for the bottom roller.
Posted : 27/08/2010 8:36 pm
Not sure about SRAM but below tells you all you need to know about Shimano 10 speed:
http://cycle.shimano-eu.com/publish/content/global_cycle/en/nl/index/products/dynasys.html
Itn short and I had this comfirmed by Madison.
compatibility is as follows:
10 speed road and 10 speed MTB - not going to work
10 speed road and 9 speed MTB - not going to work
10 speed MTB and 9 speed MTB - not going to work
the chain is a different pitch on the Shimano MTB stuff, you have to run a full groupset, the chain will not sit on either a 10speed road ring or 9 speed mtb ring.
sorry to be the bearer of bad news, but Shimano have made it all non-interchangeable.
Posted : 27/08/2010 10:14 pm
