1 x 10 dilemma. HEL...
[Closed] 1 x 10 dilemma. HELP!
[#5155559]
I have a SRAM double chainset (120bcd) with 10 speed on the back. I’d like to convert to 1x10 but the push fit bottom bracket and direct mount front mech are proving troublesome. I am not convinced that I will like it so I want to try it in the cheapest possible way. I figure I have 2 options:
1) Buy a Renthal 36T unramped chainring and adjust my current front mech so that it functions like a chain guide. The potential problem here is that the 36T may be too big, but it is the smallest chain I can buy with 120bcd.
2) Buy a new bottom bracket that will fit my oldish XT chainset (I prefer shimano to SRAM), fit a 30T unramped chain ring that a friend of mine has given me, and use my front mech as a chain guide as above. The potential problem here is that the 30T chainring may be too small and I may need to replace the chain ring anyway.
I understand that the push fit bottom brackets are not designed to be replaced, so if a go down the second option it would be a right pain in the backside (and costly) to go back to option 1.
Any help would be appreciated.
Posted : 14/05/2013 12:31 pm
Does your crank have a removable spider?
Posted : 14/05/2013 12:39 pm
I don't think it has a removable spider.
Am I right about the fact that once removed a push fit bottom bracket can't be replaced?
Posted : 14/05/2013 12:58 pm
Yep, you'll generally end up wrecking a push fit bb to get it out, so you'd need to buy a new one if you wanted to get back to the original set up.
Posted : 14/05/2013 6:57 pm
Will I get away with an unramped chain ring with no chain guide given that I have a clutch rear mech?
Posted : 14/05/2013 7:25 pm
Anyone tried to order a works components chainring there-I can't see a way of selecting what size is required?
Posted : 14/05/2013 8:38 pm
Have a look at the North Shore website. They do what you need 🙂
Posted : 16/05/2013 12:23 am
