I'm running 1 x 10 with the following:
- 34t ring mounted in the middle of SLX cranks
- 11 - 34t cassette
- SG XT Mech
The chainline appears spot on i.e. ring lines up with the middle of the cassette. However, when in the lowest gear (34-34) the cage of the mech is being pulled too far over by the chain. The consequence of this is that if you back pedal, the chain derails and drops a couple of sprockets.
The mech is aligned properly and the hanger isn't bent. I've played with the B-tension to no avail. Is the chain too short? It's not overtly stretched in 34-34 and is, what I consider, a satisfactory tension in 34-11.
Any ideas?
Cheers,
Paul
Posted : 21/03/2011 2:45 pm
