Obviously I'd need an appropriate headset.
But is there any other disadvantages of this setup. Obviously I wouldn't have the stiffness of tapered steerer, but is it any worse than it would be in a standard headtube? I'm assuming with correct instalation there would be no warrenty issues etc etc or ecess bearing wear?
I'm sure it's possible to measure a difference, but you won't notice it.
try putting them in upside down, you'll notice a difference then
don't see why they can use massive bearings which would mitigate some of the "downsides" anyway
the disadvantage is that you will know that you have an inappropriate steerer in a tapered headtube. it will eat into your very soul.
The advantage is, sometimes if someone else tries your bike they'll tell you they can really feel the difference in fork stiffness from the tapered steerer it doesn't have.
What's your combo? It never bothered me either way but I do like the option of fannying-about-with-head-angle-headsets.
Marzochi 55s in an spesh enduro frame
As long as its not more flexi than my old heckler/55 combo then it won't be an issue, as I didn't find that particularly flexy in the first place
maybe the 1 1/8" crown sat dwarfed under the 1.5" lower cup could bother you. Mine looks a bit daft, though only a 32mm fork
Lol
I'm running the setup you describe. No massive flex issues or headset problems. I've got a hope 1.5 lower headset just with a big fat crown race reducer to space it out.
If you have stack height issues then a e13 zero stack reducer in the bottom sorts that out. Takes a CaneCreek standard internal bearing. Crown sits pretty flush. Got one in my Prophet (1.5" HT) to reduce the stack height for running 160mm forks, only about 15mm heigher than 130mm forks and an external bearing 1.5" headset.
Means you can put in an angleset and slacken the front if you want.
