09 vanilla 32's, ca...
[Closed] 09 vanilla 32's, can you reduce travel?
[#534409]
my brother needs some 120mm forks and has been offered a set of these cheap. can you reduce travel like on the older models or is this not the case any more?
cheers!
Posted : 07/05/2009 3:37 pm
No
Posted : 07/05/2009 3:44 pm
Nope, but you could run them really soft with plenty of sag! If they're that cheap! I know it's not ideal and may not be too good for your frame, but....
Posted : 07/05/2009 3:47 pm
Wondered if my standard spring was a tad firm and tried the soft with lots of sag myself, can't recommend not trying it highly enough, it was truly awful.
Posted : 07/05/2009 5:33 pm
Yes you can with a spacer and either by trimming the spring or using an older (shorter) vanilla fork spring.
Posted : 07/05/2009 6:05 pm
Maybe e-mail mojo? THey do the servicing and stuff
Posted : 07/05/2009 6:21 pm
 Ewan
No - the fox website says you can't with the 09 ones, I looked into it a while ago when deciding between Vans and Floats (you can with Floats).
Posted : 07/05/2009 8:02 pm
