09 Pike damper oil?...
[Closed] 09 Pike damper oil??
[#2813518]
Does anybody know how much oil a set of 09 Pikes require in the damper?
My other/older Pikes required between 130-140ml
When I took the oil out of these ones, I measured 175ml .. and some was also spilt.
I cannot seem to find any reference to newer pikes requiring more than the 140ml??
Any help please!
Posted : 02/06/2011 4:31 pm
All Pikes listed at 120ml here
175 is waaaaaaaaaaaaay too much!
Posted : 02/06/2011 4:41 pm
 LoCo
120/125 depending on how stiff you want the lock out, if you've put the 140ml in the forks make sure you bleed it out the rebound damper before refilling.
Posted : 02/06/2011 4:56 pm
Thanks all ..
This is the 1st time I have changed oil in the damper .. surprised how there was 175ml in there???
Thanks again.
Posted : 02/06/2011 5:47 pm
Dropped the amount of oil in damper down to 125ml .. would not lock-out!!
Topped it back up to 175ml .. locks out 1st time???
Posted : 02/06/2011 8:04 pm
cheers Loco for the full Pike service kit i ordered off you tuesday,
alls working well again with em 🙂
Posted : 02/06/2011 8:58 pm
