I picked up a pair of these for my Handjob today, they're the dual air Race versions with "All Travel" for travel adjust.
I've got 2 No. 15mm spacers in the box along with the forks.
Really waht I'm asking is, the forks are 100mm travel at the mo, can I either use or remove the spacers to increase this to 115mm?
Thanks in advance
Posted : 16/05/2009 8:15 pm
You'll need to remove one spacer from the rod to get the extra 15mm. If the fork is set to 100mm at the mo, there should be one c-shaped black spacer in there.
Posted : 16/05/2009 8:47 pm
Cheers ears
Posted : 16/05/2009 9:01 pm
