08 / 09 Orange 5 ch...
[Closed] 08 / 09 Orange 5 chainrings
[#377740]
Anyone have an 08 or 09 5 and running 34 or 36 double chainset? I know with the 36 the chain just catches on the swingarm but what about with the 34?? Orange recommend a 32 but as the 36 only just catches a 32 seems a big jump down. Apparently earlier 5's are fine with the 34. Help please.
Posted : 10/03/2009 3:41 pm
i run a 2007 with 36/24 set up. The chain kept catching swingarm pivot so i fitted a spacer behind the driveside BB cup and problem sorted.
This should be the same for 08/09 also.
Posted : 10/03/2009 8:28 pm
What about chain line?
Posted : 10/03/2009 8:32 pm
i've done the same and its fine.
Posted : 10/03/2009 8:33 pm
No problems with chain line then? If my bike wasn't brand new I'd angle grind a couple of mm off the swingarm but the warrenty would go the way of the sparks. Maybe I'll try a spacer. Many thanks.
Posted : 10/03/2009 9:17 pm
not that i've noticed but then i'm not fussy about that kind of thing. nothing grinds, nothing skips, nothing hops.
Posted : 11/03/2009 1:42 pm
 Del
if you're using a double and bash it's unlikely you're going to push the larger chainring out as far as the largest ring on a triple setup is it?
if anything you'll improve chainline on average by doing as suggested above.
Posted : 11/03/2009 2:35 pm
