Fox transfer.. Don’t see an outer tube available after market
The nice folks at santa cruz have just this minute got back to me..
‘Shims are just not as good as using the correct size post, as they do not provide as much support down the full length of the post/seat tube interface, but if you are going to use one, make sure it is at least 100mm insertion.
Your frame warranty would be 100% valid, but if the shim use is the cause of any frame damage, it will not be covered under the “Manufacturing Defect” warranty’
So that’s a no from them then… Although I may risk it with a really long shim ( 15 cm plus) given I can’t see what the difference would be between that and a normal post
