Fulwood’s ok in most areas. Depends what sort of place you’re looking for really – property on the A6 is generally older, bigger and more expensive. Close to the hospital has lots of parking problems from the hospital visitors. Sherwood is ok, up by the barracks has some nice older houses, Longsands is pretty new housing developments and right by junction 31a of the M6. Keep away from Brookfield, Ribbleton, Ingol
The M55 can be a bit of a sod to get to because of the A6 which gets knackered at peak times by the Broughton lights and M55/A6 roundabout.
If you don’t want to be in Preston itself but ok for where you’ll be working then there are places like Longridge, Grimsargh which are ok.
