Viewing 8 posts - 1 through 8 (of 8 total)
  • what size of tubeless rim tape for hope enduro rims
  • coblck
    Hi what size of tape do i need for my hope enduro 23mm internal width rims do i need 25mm or 27mm
    wilko1999
    I’d say 25mm. And I’d recommend 25mm wide gorilla tape from B&Q. Amazing stuff, sticks so much easier than Stans and far cheaper – £2.97 for enough to do about 5 rims.
    johnw1984
    I did mine with 25mm Stan’s. Was a bugger to use and I wish I’d have got the Gorilla Tape.
    Just got tubeless valves, didn’t use a rim strip.
    coblck
    great will try the gorilla tape looks thicker than the stans tape
    CalamityJames
    I did mine with 25mm gorilla tape. Easy to apply just take your time and make sure there are no bubbles and the tape is centered. I used Stans valves though, because from experience they’ve been faultless.
    coblck
    Cheers guys I always put 2 layers on tape on before is it the same with gorilla tape
    wilko1999
    Up to you really, but I only needed one layer of the gorilla tape overlapped by about 3″ across the valve hole.
    coblck
    Cheers guys appreciated
The topic ‘what size of tubeless rim tape for hope enduro rims’ is closed to new replies.
