I don’t understand the furore about the ICT system. Obviously the Patent is a fully controlled system for all aspects of bike handling / adjustment – thats simply so they have absolutely every base covered in the patent.
At the moment ICT is effectively just an electronic system to control the CTD adjust on a fork and shock simultaneously, albeit without the T setting via an electronic servo actuated system rather than a mechanical system.
Ok you can set it up with different tune’s for compression etc. So how is that different to setting hi / lo speed compression damping on a fork and having a poploc or other remote to control travel adjust / lockout.
