brake mounts on a dialled are post mount?
brake mounts on a lyrik are IS….?
so this is how my order looks:
1 Shimano SLX Front Brake M665
Post Mount – LH Lever
2 Shimano XT Disc Rotor 6-Bolt RT75
203mm 6-Bolt
3 Shimano Mount Adaptor Front Post to IS 203mm
74mm Post to IS 203mm
AND
1 Shimano SLX Rear Brake M665
Post Mount – RH Lever
2 Shimano SLX Disc Rotor RT64
180mm Splined
3 Shimano Mount Adaptor Rear Post to IS 180mm
74mm Post to IS 180mm
that going to work?
and are you able to be notified via CRC when items come into stock. waiting on a 32h SunRingle Singletrack rim. then i can have a wheel built up.
don’t want to order brakes now and wheel later as i’ll be hit by postage (need to spend over €115 for free post).
cheers
J
