Thanks, but Leeds is out as I am in West Sussex.
Wrightyson: Laminate flooring is a patterned laminate bonded to a fibreboard substrate:
Top Layer – A sheet of clear paper cellulose impregnated with melamine and microscopic granules of aluminium oxide. The melamine assists the permanent bonding of the layers while the aluminium oxide affords the product extraordinary wear and scratch resistance.
The Design Layer – Four coloured printed paper that features the design and pattern of the quickstep laminate floor.
HDF Core – is a high density fibreboard and has two purposes, the first is being moisture resistant and the second is indentation resistance.
The Bottom Layer – This layer stabilises the construction while providing additional resistance to moisture.
