Speak to Magura UK they have been massively helpful to me in the past.
You can change for the latest spec oil in the damping unit ( it's different and works better at low temps apparently) and they respond well to 5mm of 30wt oil in the air side to ramp things up at the end of the stroke by reducing the volume of the air can.
I run mine with very little rebound and on the high side of the recommended pressure and I find them excellent they don't pack down at all and track very well. I find they really are pressure sensitive and 5 psi makes a big difference. I'm not too bothered about small bump stuff that's what 2.4 tyres are for!!
Mine are the 120 Marathons so the Thors may be different but I expect not.
