Just serviced my forks, and fitted the new seals using the Unior seal tool. What a joy – having used various wood blocks and sockets and all that nonsense – the seal fits onto the tool, slot into fork, the seal has nowhere to go except into the slot, few taps of a mallet, job done. Literally took thirty seconds to get both new seals in and seated, and the tool is less than a tenner. A real “why didn’t I get one of these before?” moment.
Sat here feeling immense satisfaction, while at the same time ruig all the wasted time and frustration from services past
It’s a job that can be a pain in the bum without the right tool. The right tool isn’t necessarily something designed for the job, mind, mine is a bit of PVC pipe, and my SFN Right Tool is just a bit of threaded M6 bar (thread it in from the bottom then tap in from the top, or pull in with a washer and nut if you prefer- the length of the bar makes it impossible to get it squint)
Had to replace shock bushings on a Fox RP23. Plenty of online advice that removal was easy using a couple of sockets and a vice or hammer. Persevered for about an hour getting increasingly violent until I decided to err on the side of caution and bought a shock bush removal tool for £6.50 from Ebay. Slid the bushings out out no problem in less than a minute.
I’ve had a few of those moments, as a start:
A work stand. Suddenly working on the bike is just a whole lot easier.
A track pump. Why oh why did I not buy one of these years ago???
Good cable cutters – Wonderful things, just wonderful.
A workshop size chain tool – Effortlessly removes and installs pins, sooo much better than a small one.
A grease gun – Suddenly I can get the grease exactly where I want it rather than roughly where I can get my fingers.
